Thanks @Dave
It’s working great.
My second type of pattern can you?
“Grand Total $3,100.12”
“INSURANCE PAY 4,092.00”
“Net Total: 5,974.84”
“Net Total 6,414.88”
Thanks @Dave
It’s working great.
That’s good to hear - can you provide an explanation of what you’re trying to do (it looks like pull out the total amount), then a sample text, then what you want to be matched from the sample text? Just like you did for the address portion
As i told you i have one txt file there may be string
D & E AUTO BODY REPAIR
402 WAKEMAN AVENUE / P.O. BOX 450
GRAFTON, ND 58237
OFFICE: (701) 352-3180 FAX: (701) 352-4998
FEDERAL TAX ID# 27-0759714
*** PRELIMINARY ESTIMATE ***
02/11/2019 10:46 AM
Owner
Owner: PERLA MENDOZA
Address: Work/Day: (701)360-1002
Inspection
Inspection Date: 02/11/2019 10:46 AM Inspection Type:
Appraiser Name: JASON A NELSON Appraiser License # :
Repairer
either
or
or
or
[0-9,]+\.\d{2}
Assumptions:
EDIT: If you want to make it so it looks for the words Total or Pay, then just add that a tthe beginning as a positive lookahead
@Dave
not only number
With text
whole this capture in regex
One more thing how can i search before first line capturing address regex
Don’t get the words Total/Grand Total/Pay/etc in your regex. Use the expression to pull out the numbers, then append the number to the word “Total” or whatever you want outside of the regex
i have many numbers
in txt-1 file
Total Labor: 128.90
II. Total Replacement Parts: 1,230.93
III. Total Additional Costs: 0.00
Gross Total: 1,359.83
IV. Total Adjustments: 0.00
Net Total: 5,974.84
in txt-2 file
Total Labor: 128.90
I have to find out
either
or
or
or
The first example you provided didn’t show those possibilities. Here is an updated one that assumes that you want only numbers after Net Total, Grand total, or insurance pay. Make sure for regex options that you IGNORE case (so it does not care if it is upper or lower case)
(?<=((net|grand) total|insurance pay).*)[0-9,]+\.\d{2}
I got the 6 matches from the following text:
GRAFTON, ND 58237
*** PRELIMINARY ESTIMATE ***“Grand Total $3,100.12”
or
or
or
02/11/2019 10:46 AM
Owner
Inspection
Repairer
Total Labor: 128.90
Net Total: 1,359.83
I’d highly recommend just grabbing out the numbers like this regex is doing, then if you need to add text, do it after the fact. If you truly need to grab everytihng, then just get rid of the (?<=) portion so it’ll grab it all:
((net|grand) total|insurance pay).*[0-9,]+\.\d{2}
I’m not sure what you mean? Can you provide more details or context for your question?
you gave me regex find address this
“\d+.+(, [A-Z]{2} [0-9]{5})|\d+.+\r\n.*(, [A-Z]{2} [0-9]{5})”
GRAFTON, ND 58237
02/11/2019 10:46 AM
Owner
Inspection
Repairer
then i am asking before address i haven to get first any line
GRAFTON, ND 58237
Easiest way I can think of off the top of my head would be:
Perform 1st regex to get the address and store match as a string I’ll name StringAddress
Now do a regex again on the full text and do the following:
.+(?=\r\nStringAddress)
In Uipath if you were using the matches activity you’d put it in the regex input property like this:
".+(?=\r\n" + StringAddress + ")"
Now I am going meet you tomorrow and thanks a lot
