Get Text Using OCR Microsoft engine Fail when an empty string is returned
I dont understand that when i use this activity it fails when an empty string is returned. how can i do it so it can return an empty string?
Can you share me what error you are getting?
@Rowley101
You can check empty value like below.
    String.IsNullOrEmpty(varGetText)
    Or
    varGetText.Length > 0
Why don’t you try with tesseract(Google) OCR and try the results, also try to check the invert color option in ocr setting might it will give good results
Thanks
