Why version 2022.4.3 menu Community license is gone
how can I get a community license
Hi @pawaritp
The Community license is not gone. Could you please provide more context about your issue?
A post was split to a new topic: This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package”
Yoichiさん
回答ありがとうございます。
動きとしては
クリック要素を探す
クリックする
要素をループさせる。
という流れで、要素を探すとクリックを一回ずついれてループさせたいです。
その場合は要素のaanameの箇所をvとすれば、要素を探すとクリックのループが可能でしょうか?
最終的に開きたいページを変数にいれて、表示されたら終了としたいです。
作成してみたもののクリックを5つ要素を探す5つ入れるとすると、ループの作りにはならなくて困っています。
ご教授宜しくお願いいたします。emphasized text
Hi, i have the same error, i can not resolved yet. Please, i need help!
“the key machine is already linked to another machine”
I have a problem right at the beginning, clicking on sign-up I get this error:
the read operation failed, see innere exception.
I thought it might be a firewall error, but ui-path studio seems to have access to the ports, also the account is still valid
Same problem here. Did you find a solution?
Hi @lorenzo.olivier @Renato_Luiz_de_Souza
Did you manage to resolve this issue by following the documentation link?
Hi, the solution I found was to upgrade my OS to windows 11. I have no idea what caused this problem.
Thanks
UiPath Studio is a cloud-based application that provides users with a complete solution for automating business processes. You can use Studio to create workflows, build applications, and manage data.
- Downloading Studio
To begin using UiPath Studio, you need to first download Studio. 2. Configuring your robot
After downloading Studio, you have to configure your robot. To do so, click on “Configure Robot” at the top right corner of Studio. Then, follow these steps:
a) Select the type of robot you want to use.
b) Enter the name of your robot.
c) Click on “Add”.
d) Choose the location where you want to save your robot configuration file.
e) Click on “Save”.
f) Click on “OK”.
g) Wait until Studio finishes configuring your robot.
h) If you want to change any settings, click on “Edit Settings”.
i) Make sure that the robot is connected to the internet.
Hello. I have installed the uipath and can log in. However, it pops up me an error saying “Unable to load DLL ‘Shcore.dll’ or one of its dependencies” when I open it. Could anyone help me with this? Thanks a lot.
Hello. There was a problem when working with the android studio emulator.
If I tap on the bottom of the screen, then an error occurs tap at (x=360. y=1146) has failed.
On a physical device, this problem does not occur, this problem only appears when working with the android studio emulator.
How can you solve it?
I tried to specify increased values for viewportRect in additional desired parameters {“left”:0 “top”:90 “width”:800 “height”:1200}
- did not help
Hey, So I downloaded Studio, but got studio X. When I go into settings to change to studio, it says “cannot change the local license while connected to orchestrator”. When I go to orchestrator, it seems as if I only have the capability of using studio X.
My question is why is that? isn’t Studio also free for personal use? I’ve had studio in a different client, and now that I’m trying to get it onto this one It’s only allowing me to use X.
This must be because you are on a free enterprise trial cloud account and not a community cloud account.
I think there is currently one solution:
- create a new community account instead of the trial account
The current Pro Trial accounts expire into a Free enterprise tier account which only contains StudioX.
You’re a Champ. That was the exact answer I was looking for and I am on the verge of creating a new account. Thank you for your input!
okay okay okay
