Hi All
I am facing a for each looping with continue issue
I had a excel row 0 that the number 1-31
The first loop I want show 1-5 only and then break it
The second loop I want to start from number 6, then I using continue to skip 1-5.
1-5 can perfectly skip. The problem is start at 10, I had set the message box to check Before IF the number is running to which index, 10 can appear at Before IF: 10 and then it go back to the beginning of the loop until run to 31.
