FlowChart - Can we connect more than 3 connection on Flow Decision? How?
Hello creator !
can we connect more than 3 connection on flow decision. I am not able to connect more than 3 connection on the flow decision. Can i get solution on this ?
Srenivasan Kannan
@SrenivasanKanna
Flow decision is only 2 option activity it can check only True Or False value, if you want to use more conditions, try to use Switch Activity or create another flow decision after the 1st one.
