Hi there,
joined “Reboot Your Skills”, your 4-week introductory RPA learning program yesterday.
Installed UiPath Studio today & started the first lesson (Unicorn name).
First of all: Whenever using UiPath Studio, I have to re-install the Excel Add-In, otherwise Studio will not find Excel at all & sends an error message.
How can I change that?
Working with Office 2010 (unfortunately).
When checking Excel Options, the UiPath Add-In is always on Inactive Status. Excel keeps pushing it to Inactive & I don’t know how to change that.
Second problem:
When running the first assignment, it starts out looking good, getting the name from the unicorn xls file, entering it in the dedicated website but then it stops, freezes for a while and after some time the following message occurs:
RemoteException wrapping UiPath.UIAutomationNext.Exceptions.NodeNotFoundException: Could not find the user-interface (UI) element for this action.
Possible solutions:
• Ensure application is opened and the UI element is visible on the screen at
execution time
• Edit the Target of the UI activity and use Validation to debug the issue.
• If needed, re-indicate the element as its properties might have changed
• Use “Check state” activity to check the application state before executing the action
• Increase the “Delay before” value to allow time to the application to render entirely
and become responsive
at UiPath.UIAutomationNext.Activities.TargetCommonLogic.d__8.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at UiPath.UIAutomationNext.Activities.TargetBase.d__40.MoveNext()
at UiPath.UIAutomationNext.Activities.NGetText.d__11.MoveNext()
at UiPath.Shared.Activities.AsyncTaskCodeActivityImplementation.EndExecute(AsyncCodeActivityContext context, IAsyncResult result)
at UiPath.Shared.Activities.ContinuableAsyncCodeActivity.EndExecute(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.System.Activities.IAsyncCodeActivity.FinishExecution(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.CompleteAsyncCodeActivityData.CompleteAsyncCodeActivityWorkItem.Execute(ActivityExecutor executor, BookmarkManager bookmarkManager)
No clue about that.
Can you help me out please?
Thanks & kind regards,
Jane
