Find difference between two numbers using try catch and retry scope?
can anyone help me with this ?
I read two data from two coloumns and wrote the difference between them into third. Now i need to use catch and retry scope . Where will i use it?
Hi @Minto_Sunny
May I know why u need retry and try catch here
it is a question . i found the first part . But now i need to use try catch and retry scope. Since i am a beginner i don,t know where it is applicable
Hi @Minto_Sunny
For better idea u can refer Uipath academy or YouTube channel for this
Exception Handling - Part 2 | Use of TryCatch, Throw, Rethrow and Retry scope | UiPath - YouTube
Hope it helps you
Regards
Nived N :robot:
Happy Automation :relaxed::relaxed::relaxed:
