Failed while running portal caused by a task was canceled - while trying to build cube using the UiPath Insights Admin tool.
- Log into Insights website using the UiPath Insights admin email address and password.
- Go to https//insightsservername/app/test and check if all the services are running.
- One of the causes of the error is query proxy service will not be running.
- Query Proxy service is responsible for internal communication between crucial components which are IIS (w3wp.exe) and Sisense.ECMS
- Try browsing HTTP://localhost:14996/paths and check if there is a response. One possibility could be it prompts to enter username and password which is not supported.
- Check the authentication in IIS Server for Sisense.web site and ensure "Windows Authentication " is disabled while "Anonymous Authentication " is enabled.
- With the right authentication, Proxy Service will run without any issues and it will also allow communication with ECMS service which will allow cube build.
