Facing problem to create endpoint url for Appian Connected system
Hi UiPath Team and Community,
I’m trying to integrate UiPath Orchestrator (Cloud) with Appian using the UiPath Connected System plug-in provided by Appian.
The issue I’m facing is with setting up the correct endpoint URL while configuring the connection in Appian.
:wrench: My Setup:
  • UiPath Orchestrator URL:
    https://cloud.uipath.com/tryrhhfgtty/DefaultTenant/orchestrator_/
  • Tenant: DefaultTenant
  • Folder Name: Folder1
  • FolderId: 444445 (from URL)
  • Authentication Type: Using Email + Password (basic)
Try end point URL in below format
https://cloud.uipath.com/[accountLogicalName]/[tenantLogicalName]/orchestrator_/odata
https://cloud.uipath.com/tryrhhfgtty/DefaultTenant/orchestrator_/odata
Also refer below link
Marketplace - Appian
i tried , but error was same
