@soumi_soumiya can you share one more click activity selector for another person other than this.
you can save your mails using save mail message activity…then use start process activity to open your mail in outlook…and use get text activity to retrieve text.
had done already
will try
Thanks for your reply…
But I am using outlook i had configured. My problem is that only the click activity. To click the received mail so that i can scrap the data that is in body which is in an html format. But using this click activity it keep on click only the first received mail but as time as the number of unread mails that matches with subject.
Custom activity to extract tables from email:
https://go.uipath.com/component/extract-tables-from-mail-839f39
It takes mailmessage as an input and returns a dataset with all the table content in the email.
