The task is as follows. (step 1-3 has to be done by the robot).
Read the Calculus.xlsx. Add a column ”Result”. If number > 1 number 2, subtract, else multiply them.
Expect a tax rate of 15 %. Add another column that adds the taxrate to the result
Save a new Excel-file with the results – The naming of the file must contain today’s date following this format: YYYY-MM-DD_Results.xlsx
I’m a newbie at Uipath almost a week in, so please bare with me. I seem to have reached a dead end here. have managed to finish the entire task. It’s just that the outcome is not as it should. A new excel file is created it’s just that the columns for “result” and “taxrate” are empty and the “taxrate” results meaning the numbers are also added to the sheet it’s just that they’re not where they are supposed which is under their respective column. Calculus.xlsx (14.9 KB) Main.xaml (19.3 KB)
Please find the attached xaml file , I developed a flow as you expected and I also share the input, output excel also 2021-12-13Results.xlsx (7.3 KB) Calculus.xlsx (15.6 KB) Main (1).xaml (11.6 KB)
to continuation my answer to your old post for the same question please find the attached work flow. if you have very limited rows you can follow the solution provided by @Robinnavinraj_S or if you have so many rows please refer the attached work flow which is developed by using write cell activity, excel formulas and Auto fill it will process the rows in fraction of seconds. thanks.
I don’t know what mistake i keep making but when i adopt your workflow i keep getting error messages. I will send you my workflow. Maybe you can see why it’s not working as it should. I noticed that you left out the excel application scope in the version you sent me? isn’t it a must in order for the robot to be able to know where to look in order to perform the task?
If possible it would be to great help if you can upload the whole solution(including the excel scope) so I can see how you’ve thought.
Thank you so much for your quick response and the updated worksheet. Unfortunately, I am still experiencing issues with the flow. Please see the attached image in it you will see the error message the code has resulted in.
Thank you so much this finally did the trick :-). I really appreciate you taking your time to assist newbies like me, it’s because of people like you there is hope for humanity :-).
I hope you don’t mind me asking you for help with another uipath question, it’s probably super easy for you as well, but it would really help.
