Getting below error while invoking PS1 file using Invoke Power Shell…
Kindly please, give me solution for same.
Before write power shell command and check it.
Hey @Lalit_Chaudhari ,
In the properties section of Invoke Power Shell change the Type Argument to System.string.
Delete the variable output from variables panel and recreate it by clicking in the Output property and Ctrl+K
This way of declaring variable creates the variable with required datatype.
thank you found this is helpful to me
thank you found this is worked to me
