Getting the error when using the Workbook: Read Range activity.
Error: Read Range: For indents, only left, right, and distributed horizontal alignments are supported.
hey
are you using the workbook read range activity?
regards
No. I am using the Workbook read range activity
can you change for excel application scope and inside the read range activity (not workbook) and try again
regards
Was able to read the first excel sheet, however, I got this error when trying to read a other sheet on the same excel file.
RemoteException wrapping System.Exception: Job stopped with an unexpected exit code: 0xE0434352
Note: Excel installed on the systems does not have a subscription so not sure if this can cause an issue.
can i see your code please?
please try the following
create a variable in the scope workbook propertie and the pass it to the close workbook
Still getting the same error. UiPath Executor keeps crashing on the second excel application scope read range
can you try with downgraded your excel package pls?
which version should i downgrade to?
excel pacjage
same error appears when opening the second excel file
Thank you for the assistance, this was the cause. On the sheet I saw less that 20 rows but maybe there is some text hundreds of rows lower down.
