Hi all,
I am working on a question in UiPath Academy RPA Developer Foundation.
I do not understand why my workflow doesnt work.
@yodeedee Can you explain what issue you are facing with screenshot or error message so that we can help.
Hi all,
I do not understand why my workflow doesnt work. Under ‘Catches’, I want to generate message at output panel with ‘Log Message’ Activity, but it does not appear even if the workflow proceeds to Finally>If > Then> Message Box ‘Bye’.
Please help thankyou.
The scenario is that I will closed the browser with my desired url for exception to happen.
If there is no error in the TRY part, it won’t execute the catches block @yodeedee. May be that is the reason your catches block doesn’t execute.
Hi @yodeedee
If you know that you will encounter an error you can use Throw Activities and it will go to the exception .
cheers
Happy learning
Hi HareeshMR, thanks for replying to help!
The exception that I am trying to catch is that browser is not present during the execution (as seen inside TRY). In order to make error in the TRY part, I will not open the browser so that exception can happen. Does it make sense?
Hi pattyricarte, thanks for helping!
Do I put the Throw inside the Try? What do I put for the expression for exception in Throw?
It depends upon you. You can put bussines or exception.if you put exception it will terminate the apps.but if you have bussines rule then just put the bussines exception @yodeedee
Hi @yodeedee
What excatly do you want to do?
You want to open chrome with the given url ?am i correct ?
cheers
Happy learning
Hi pattyricarte!
I want to collect data from browser. The first step is to open the browser page. I want to implement a TryCatch to make sure the correct browser page is open before user runn the workflow. So I think the Catch is still not catching the exception. While Throw Exception will work, but it seems to stop the workflow once exception is countered. I want the workflow to continue (at Finally) to either tell user to ‘Open browser page’ (during exception) or ‘continue on browser’ (Without exception) so I would still wish to use TryCatch, in the case. I am lost at how to fix it.
