Hi @Nk511
Have to tried updating the excel activities from the manage packages to latest version?
Is the excel installed?
Regards
For now, can you try to use Repair Tool for Microsoft Office, as the following document?
Yes it is installed
Im using Studio, bot studioX
Not*
Hi
Welcome to uipath forum
There are two options to handle this
Either you can use WORKBOOK activities instead of excel so that we donât need to rely on excel application so that it can run even without excel application
Or
Try with reinstalling office with trouble shoot steps
this attached document UiPath Excel Addin Installation Troubleshooting v4.docx (388.6 KB)
Cheers @Nk511
I have reinstalled office as well as reinstalled Uipath. Checked all excel add in options etc. It works in my other laptop but not in thisâŚ
Can you elaborate on workbook activities? U meanbi can skip using Excel Application Scope?
I am new to Uipath
I did, no use âŚstill same error
Yes
In activity panel when you search as workbook you get the same set of activities as in excel package
When itâs used it doesnât need excel application scope and can directly use workbook activities
Cheers @Nk511
Ok. I see it. I was trying to link a simple excel file and see the output by using âExcel Application Scopeâ with âRead Rangeâ. Now how do i this using Workbook?
Fine
Delete those two activities u have now
Then go for activity panel and search as WORKBOOK
Under that you can find READ RANGE activity
Double click that
Here you can mention the filepath
Cell range
Sheetname
And output variable name
- same as excel package
Cheers @Nk511
Oh my god! I have been stuck since Wednesday, and you solved my problem. It worked. Thank you so much brother. Could you please exaplain why was i facing the issue and what is the reason it works now?
The issue you were facing is something with the excel application level
Just on few patch updates that error might be rectified
And now it got resolved because we didnât rely on excel application itself as we were using workbook
That is this activity can run even when excel is not installed
Cheers @Nk511
Ok, so is there anything i would be missing on if i rely on Workbook instead of Excel ? Also is there a way i can the error and be able to use Excel activities as well? Nevertheless, i cant thank you enough âŚappreciate your help.
No not really
It has to be troubleshooted once to check where the exact error has occurre
Cheers @Nk511
