Empty Email Body Using Gmail
@anmita What was the Output of this Expression ? Did you Check it?
Yes I tried it so it was showing blank.
Then I tried using item.IsBodyHtml.ToString just to check but still there is no output.
Can you share the workflow if you have tried implementing it ?
@anmita , There is no change in the Workflow, Just using a Write Line to Print the values in the Output Panel.
However, Below is the Workflow :
Main - Copy1.xaml (14.7 KB)
Thank you @supermanPunch for the workflow
But even this just shows blank output
@anmita ,
Just For Confirmation, Could you Send the Screenshot of the Output Panel ?
And the Write line output is
  1. True
  2. Blank
  3. Html format
@anmita , The HTML Format would be your Email Body.
Could you write that HTML format body into a Text file and Check it’s contents.
We can confirm if it contains the parts of your Mail body.
