Element not found or BOT did not click on button when BOT run on a silent way (Silent way mins system is in a lock state)
any one have idea to resolve issue
Check if the bot license is Unattended license, If it is attended license then system should be turn on
Hope this helps you
Thanks
attended license is used
Attended license bots will not work when the screen is locked / Minimize mode
Hope this helps you
Thanks
Hi @suraj23
Is you’re robot is licensed?
If it is not a licensed robot, then it can’t work on lock screen.
Thanks.
Hi @suraj23
In the attached screen shot, I can’t find the license details.
Kindly go to your profile in orchestrator, under general column you can find the license.
Thanks.
