Element exists에서 팝업선택이 안됩니다. Pop-up selection does not work when element exists
check element, check app state, element exist 모두 팝업을 클릭을 못합니다.
이미지로는 가능하나, 해상도 문제로인해 UI 프레임워크로 하고 싶습니다.
기본값 AAA UIA 모두 팝업 선택을 안합니다.
다른 플랫폼 이슈로 인해 Chrom에 확장프로그램 재설치도 해봤는데 안되네요
혹시 아시는분있을까요
Check element, check app state, and element exist all pop-ups cannot be clicked.
It is possible with images, but due to resolution issues, I would like to use a UI framework.
Default: AAA UIA All pop-ups are not selected.
Due to other platform issues, I tried reinstalling the extension in Chrom, but it didn’t work.
Does anyone know?
Do you want to check if the image exists or not? You can use the Image Exists activity. It is a classic activity.
If the above does not work, try using the CV Element Exist activity.
Hope it helps!!
