I have a problem about Edge Extension. It used to work normally, but suddenly it didn’t work well. Before using it, I have to reinstall it every time.
Hi @Monthita_Kiatruangchai,
The new Edge is running under chromium engine. Please make sure you are using the same browser profile on which extension was installed. Otherwise extension might have an issue.
