Hi
Can any one help me this this?
Edge extension is installed and enabled but but not able to use it in uipath selectors and it give the error that edge extension must be enabled.
Hi
Hey,
Firstly please take a look to Edge extension troubleshooting:
and check this topic:
You can take a look on @pikorpa provided links
If you are using any older versions of studio, suggest to upgrade and try again
Also, let us know are you using community / Enterprise version?
Thanks
