Double click before enter data to some field using same typeinto activity5
My problem is when i need to enter data into system field should double click on that element to take editable mode.
When i used the double click activity and moving to enter data into that field using typeinto activity that field is going to non editable mode in that system.
Then this should use same typeinto activity.
But that activity only having single clickbefore typing property itself.
Does anyone having any solution for this…
Will the box be editable if your set focus on it and do Enter twice?
@nadim.warsi
It worked. Thanks
