Double click as a hot key
Hi all,
Can anyone please tell me of how to use double click in webpages with send hot keys.
Thanks in Advance
@Palaniyappan
I think there is some confusion there… Double click is done with mouse and hot keys with keyboard…
@Shivaraju
You can use Click activity instead of Send Hot Keys
But any specific reason you are looking for hotkeys?
Try to use Activites instead of passing Hotkeys
Mark as solution if it helps you
Thanks
Hi @Srini84 , @bcorrea
Thank you for your replies.
Actually am working on a citrix application and using image automation on it. When I click a particular image on that application, the element image will change and not fixed it changes but the cursor position will be at that location only. I need to double click on that image for further actions but unable to click on that image because the image changes and not a fixed image. So I want to send double click as a hot key to perform a double click action.
