Dear Masters, i am new to Uipath. Need help in solving this problem
This is the string
{“phoneNumber”:“329-159-3517”,“startDate”:“September 21, 2015”,“employeeID”:“1013”}
and i need to copy phone number, start date and empid and paste in web.
Moreover, this data order is changing dynamically like this.
{“startDate”:“December 22, 2019”,“employeeID”:“1019”,“phoneNumber”:“449-667-9275”}
Help me to solve this problem.Tq
@Lokesh_M1
Welcome to the forum
In general your string looks like JSON and you can deserialize it and handle it like JSON
As an alternate you can do the following:
grafik
Ensure following:
grafik
we parse the JSON string into a dictionary and you can handle is as usually like:
grafik
It is showing like this
With all respect - this is the worst advise ever :-1:
The text seems to be a JSON and there are wery efficient methods how to manipulate JSON - like recommended @ppr :+1: It require a bit of .NET knowledge indeed. But that’s life with UiPath
ensure following:
grafik
Kindly note the typo Desaralize vs.
JsonConvert.DeserializeObject(Of Dictionary (of String, Object))(text)
You may try also the attached simple workflow demonstraing the basic JSON operation
WorkingWithJson.xaml (7.4 KB)
Thank u very much Peter.Its working
Sure sir, I will try.
