Dear Master, Pls provide solution or code for this problem with out using IF condition
Problem for forum
Here if VALUE is numeric,write ‘458’ in OUTPUT column
if VALUE is the alphabet,write ‘zxy’ in OUTPUT column
if VALUE is a symbol,write ‘^&*’ in OUTPUT column
and Final Status be successful
if there is no data, FinalStatus is Unsuccessful.
Here i should NOT USE IF condition.TQ
Pls provide solution.Tq
In this case, I recommend to use Dictionary as the following.
dict =New Dictionary(Of string,string)From{{"numeric","\d+"},{"alphabet","[A-Za-z]+"},{"symbol","\W+"}}
judge = New Dictionary(Of Boolean,string)From{{True,"success"},{False,"Unsuccess"}}
Then
m =System.Text.RegularExpressions.Regex.Match(CurrentRow("data").ToString,dict(CurrentRow("value").ToString))
m.Value
judge(m.Success)
Sample20221201-4.zip (9.1 KB)
Hi @Lokesh_M2 ,
What about below workflow
Workflow
Xaml
Sequence7.xaml (3.5 KB)
stOutput
If(Row(“Value”).ToString.ToUpper=“NUMERIC”,“458”,
If(Row(“Value”).ToString.ToUpper=“ALPHABET”,“zxy”,
If(Row(“Value”).ToString.ToUpper=“SYMBOL”,“^&*”,“”)))
stFinalStatus
If(String.IsNullOrEmpty(Row("Final Status ").ToString),“Unsuccessful”,“Successful”)
Best,
