Data type of item in for each loop for UIelement collection is not recognized in click "Target/Element "property
hi there,
when I try to invoke item in for each loop for an uielement collection variable in click activity- element property, it is not recognized as “Uielement” type as below.
I have tried to convert item from object to “UIelement”, but seems there is grammar error.
I have uploaded the project file, could anyone help me?
Sequence.xaml (12.3 KB)
hello @zangyuchen2008
your xaml file is missing some assembly reference/s…
I edited your xaml for assembly references (via Notepad++) and it worked…
I recommend, try creating a new xaml and check if it works…
let us know even if creating new xaml dont work for your issue…
Hello this is a new project I created, still has the same issue.Main.xaml (8.1 KB)
try with this xaml Main.xaml (5.1 KB)
and if you happen to see any error… post error screenshot…
The same error as before
I have found the root cause, the for each activity property-“TypeArgument” should be set as the right one
