Data Scrapping Help Required
Hi All,
I have a requirement, where i need to scrape the table from a site:
So when I search I get this output
Now when I use data scrapping I get 1, 2, 4, 6 and 8 rows scrapped in my datatable, where as the rows without a location are not scrapped.
So I want your help to get a solution for this where i can manage to scrape all rows from this table.
Thanks a lot in advance.
Thanks
Anil Kumar
  1. Try Taxonomy
  2. Either Scrape it one by one And then Paste it to an Excel,
Thanks,
But its a website table, as its not an image or something.
I can directly use data scrapping but if there is any advance setting or changes required want to know it.
Taxonomy: you need to use Intelligent OCR?
Yes Correct, if your system Can use Abbey or ML Extractors, you can easily use Taxonomy.
Well, thanks but both are paid version.
I want to simple solution as Abbey is paid and this task is not worthy enough to use it.
Thanks
These elements are not continuous selectors like a table. Hence they will have to be extracted one by one and put it in an excel.
Taxonomy may not work here as this is website table and not a scanned image.
Thanks a lot for update.
Now please help to get a solution to this problem?
