Create variable error for boolean displayed- not able to fix it. Please help
I am new to Uipath and at beginner level. Trying to set a variable for Image exists activity. Ctrl+K is not listing boolean and throwing the below error. Just typing boolean in the output field is listing boolean variable but agian throwing the same error. Please help with the fix.
boolean error1 boolean error2
@gangakoyada1
Boolean is a reserved word in Vb.net, so you can’t place that as a variable name, instead you can create with another name, but the type will be the boolean
Eg: ButtonElementExists = Boolean Type
Check for reserved keywords as below
Hope this helps you
Thanks
Thank you Ksrinu for your help. It worked and sorry for the delayed response
Hi @gangakoyada1 !
Don’t forget to validate @Srini84 post as a solution to your problem if it’s alright :wink:
