build data table create in main work flow and try to access inside workflow not work.when try to add data row shows null value
Are you passing the datatable that you build in the main workflow to the child workflow as an argument?
yes I pass and in child workflow I create one assign activity and pass this value to datatable using add data row but in datatable got null value
