Create assets with same name and different values when they are specific to robot
#1
What is the use case
I have two VDIs which read the config file from a shared folder. When both VDIs try to access the file on a shared drive at a time it eventually causes one of the bots to fail.
How do you see a solution for the use case?
If I can create two assets with same name and different file paths(local drive paths) using per robot option bots can run individually without any conflict.
Scope:
  • Assets
  • Automation Framework
#2
Hi @rahamtullah,
If you create the asset per robot option, it should not conflict .Because you are configured the local path for the Robot.
Regards
Balamurugan
#3
Hi @balupad14
My bad… Thanks for correcting me.
I was trying to create a new asset altogether with the same name which confused me.
Rahamat
