Attempt 1: They update UIPath application midway my exam from 19.5 to 19.6 and the it hanged every time I tried to debug the solution, couldn’t stop the debugging. I had to force close the process from task manager and reopen it again and again, taking a lot of time.
Attempt 2: The Catches block was not catching my BusinessException even after using UiPath.Core.BusinessRuleException. I wasted a lot time here and after a while i removed it and inserted back manually. Then it worked but I had lost substantial amount of time over this potential bug. Later I struggled with converting datarow to datatable, got it eventually after the exam.
And while debugging the code I didn’t knew we have to click continue about 6 to 7 time to throw it to the next activity. I was struggling for it to go out but it never did, I just continued clicking on continue and then only it moved out.
Are these bugs or this is the way it works?
Also, please clarify the following issues:
- We don’t need to use dispatcher-performer until stated in the problem statement, right?
- Exactly which files are required to be uploaded, the whole project, or just the xaml files with output excel.
I have completed L1, L2 and L3 including two assignments but couldn’t upload solution in time. Doesn’t feel right at the moment I would take my last attempt in a few days.
