Copy csv file to excel with decimal problem after decimal point
Sure, bcause it is thousands separator.
i need to keep this configuration system in my computer
Hi @Soudios
It’s Working Check the screenshot.
Regards
Gokul
@Gokul001
Its working with a specific number i need it to work with a hole csv file
Hi @Soudios
Share the CSV file
@Gokul001
I can’t share it with you, what do you need to know about the csv file ?
Hi @Soudios
Can you share a dummy CSV file and error screenshot
As stated before it seems to be locale settgins conflict:
  • your CSV is using comma as decimal separator
  • your system is comma as thousands separator
I recommend you to resolve it by replacing β€œ,” by β€œ.” in your number, e.g.
MyNumber = β€œ123,456”
MyNumber = MyNumber.replace(β€œ,”,β€œ.”)
This is a dummy solution but should work.
@Soudios
Can you share the Dummy CSV file?
Otherwise, I cant help you…
Here an example of numbers with 2 decimal after coma
in your code i need to replace β€œMyNumber” by a csv file
The solution proposed by @ppr before works well for all variants:
1 234,56 β†’ 1234.56
234,56 β†’ 234.56
234,567 β†’ 234.567
1 234,567 β†’ 1234.567
MyNumber = β€œ1 234,56”
MyNumber = Double.Parse(MyNumber, System.Globalization.CultureInfo.CreateSpecificCulture(β€œfr-FR”)).ToString
Howgh
@J0ska
I have 200000 row in this file, did a need to add MyNumber= β€œ1 234,56” 200000 times ? :slight_smile:
This is a different story - you read CSV into a datatable and seems you do not know how to apply the formula to the datatable.
How can i do that ?
This is quite common topic. Many resources about this topic in this forum and Internet.
Search pls.
@J0ska
Ok no problem if you don’t know how to do it
Anyone knows how to do it with the hole process plz ?
Hi ,
Can you try this method, auto fill range can be extended till last row.Main.xaml (8.8 KB)
sample.xlsx (8.7 KB)
