Configure ephemeral indexes with context grounding - Issue adding index
Hello All,
I have imported NDAComparisonSolution 1 from Agentic Automation Training.
I don’t see " In the properties panel, you’ll see the option of Use File Inputs to add the context, please help
@Ranveer_S_Thakur
Can you please show a screenshot here
cheers
@Ranveer_S_Thakur
Please check below points-
  1. Make sure you imported the correct solution/package version used in the training.
  2. Check whether your UiPath Studio / Agent Builder version matches the one shown in the course.
  3. In some versions or preview features, Use File Inputs may appear only for specific activities or only when the required feature is enabled.
  4. Try opening the activity properties again after selecting the exact Agent Builder activity where context grounding is expected.
  5. Also verify whether any required package dependencies are missing or need an update.
If possible, share:
  • your Studio version
  • Agent Builder package version
  • a screenshot of the selected activity’s Properties panel
That will help confirm whether this is a version difference, missing dependency, or feature availability issue.
Hello @Dhruba_Jyoti_Kalita @Dhruba_Jyoti_Kalita .
I am using Web Studio, how to check version or how to enable it (I am using enterprise license)?
Here’s the screenshot:
Please guide, thanks!
