"Computer" object does not contain ".info" and other objects after Microsoft.VisualBasic.Devices namespace is added to project
#1
Looking to get some basic robot computer stats before a process runs. Using the Microsoft.VisualBasic.Devices namespace I should be able to this (as well as other info) but “My” is not available in the UiPath nor is “Computer.Info”
My.Computer.Info.TotalPhysicalMemory
Any ideas?
#2
Hi @bnott,
After adding the Microsoft.VisualBasic.Devices namespace, you can create a variable of type Microsoft.VisualBasic.Devices.Computer and instantiate it with the expression New Computer(). Then, you can access the properties of the created variable like this : myVar.Info.OSFullName for example.
Hope it helps.
Regards.
Masiré.
#3
Yes! That makes total sense now. Thank you for the quick response!
closed #4
