Completed RPA developer foundation still same modules for Automation developer associate training and Developer professional training
I have completed RPA developer foundation in May 2023. Now in the Automation developer pathway, there are three learning paths namely Automation Explorer Training, Automation Developer Associate training and Automation Developer professional Training. I have noticed that three of the learning paths have the same courses (modules) that RPA Developer Foundation has. As I completed the RPA developer foundation learning plan, is it necessary for me to complete these 3 additional learning paths.
I request the course makers of UiPath academy to merge these. Like if one completed a module or a course despite of his learning path, the course should be completed in all learning paths wherever the same course exists.
@Vankayalapati_Varun_Chowd
The versions of the studio’s used might be different so there are different plans and also depending on the type of certification and level the courses are merged
Hi @Anil_G
Should I need to do the same course again for the new version of Studio.
If you are interested you can…else as you already did the course very close to new version it should be fine
cheers
@Anil_G
But RPA developer foundation certificate is not visible in UiPath Digital Credentials page
Certificate are visible when you write some certifications
these are courses you will get course completion badges only
cheers
@Anil_G
I have an offline certificate (pdf copy from mail) for RPA DEVELOPER FOUNDATION. I am unable to show case it in UiPath Digital Credentials website.
Hi @Vankayalapati_Varun_Chowd ,
With the modules you have completed, there is no need to study again
Many courses have similar overlapping modules
UiPath digital credentials are for the certificates…what you got is a course completion diploma
