What versions of Abbyy Flexi Capture (FC) Studio can be used to develop templates so that it can be process documents in UiPath?
Abbyy FlexiCapture Studio (FC Studio) is a stand-alone tool that is used to develop templates for processing invoices, bills, etc. Once these templates are built, they can be used with ABBYY Activities Package and extract results as desired.
The ABBYY activities use FlexiCapture Engine (FCE) to process these documents. FCE is a runtime tool compared to FC studio and the difference in versions can cause inaccurate results or lead to unsupported exceptions.
The below matrix can be used for reference in choosing the right versions of FC studio and FCE. This will avoid any conflicts and ensure smooth processing of the data:
FlexiCapture Engine | FlexiCapture Studio |
12.1.24.7 | Abbyy FlexiCapture 12 Release 2, Update 10, Build 12.0.2.3118 or earlier |
12.1.23.17 | Abbyy FlexiCapture 12 Release 2, Build 12.0.2.1356 or earlier |
12.1.24.10 | Abbyy FlexiCapture 12 Release 2, Update 7, Build 12.0.2.3042 or earlier |
12.1.23.17 | Abbyy Studio version 12.0.1.263 (major distributed version) |
