Hi @Anil_G is it possible to add first all data into action center and then what ever the ticket approves next to get the approved ticket data
Yes you can use this activity to get the tasks submitted
https://docs.uipath.com/activities/docs/get-form-tasks
Did you use the the orchestrator process template as this is long running process?
cheers
Generally for human intervention processes we use this
The settings are different
cheers
@Anil_G i haven’t tried this i will try once this but my flow is built completely as of now but i will try to modify if i can
@Anil_G This i can’t use because this is something different and i haven’t used it before also
Yes Persistence i already enabled it
I have seen some other Posts on these topic and tried those not working, i struck on the wait for document validation part only. I’m just confused how can i resume the task in unattended mode
Get form task won’t work for me because I’m not using form Action here.
Now I’m able to create the tickets in action centre but not able to get or resume those after approving that ticket.
Just to be sure… Can you create a sample task using Orchestrator process and check if that is working for you
cheers
