Hi all,
I came across a very odd bug. I have a requirement where an item needs to be picked in a select/combo box.: see the highlighted item below. After the selection, other elements are populated in other menu’s. When I click any of the values in the dropdown, it works, but for some reason on 3 items the click is performed on “Pers nr :” field instead of in the dropdown. It seems there is a conflicting overlay or something going on…
I have tried workig with “select item” but this option does not work.
How to avoid this and how to fix this problem?
Other option I think of is to perform the click on the left of the item using cursor position (e.g. OffSet X: -300, but no results) but how to do this?
Thanks a lot.
Best regards,
Kris
