Click Offset Not available for Click activity
Hi, for some reason i can’t add a Click offset to my click activity it is set as null and i have no option to change that from null. I am using the newest version of studio with modern activities.
Anyone knows the reason why?
@Morphyum
Welcome to the community
  1. In modern design first you need to indicate the element to enable options
  2. In modern you can set offset directly while editing element…click on edit element then if you hover over target you will see settings icon …if you click that then target plce can be moved and set…check the image
Hope this helps
