Hello all,
I used click ocr text on sap application but is this not working
Any one have an idea about this issue
Best regards
Hello all,
Best regards
Hello @nora_ziani
Are you doing image based automation on the applciation? Or have you enabled the scripting in both sap and in the client ?
If yes, you can use Normal click activity.
Thanks
i have this pop up after the connexion ,i did not undestand why this pop up
Best regads ,
thank u lot
Hi @nora_ziani,
In my experience OCR is not efficient so user runscript method, kindly refer below videos list hot it will help you.
Best,
hello,
I used computer vision , is it also good approach or no? until now i have not any ssue with this method
Best regards
thank u lot
@nora_ziani
that popup cannot be handled normally by uipath because it blocks execution (similar to how a messagebox stops your process from continuing unless you manually click it)
you can manually disable that popup before you run your automation by doing the following
https://blogs.sap.com/2015/06/09/tips-stop-the-pop-up-sap-gui-security-remeber-my-decision/#:~:text=Go%20to%20your%20Windows%20start,on%20Security%20folders%20Security%20Settings.&text=To%20modify%20it%2C%20click%20on%20Open%20Security%20Configuration.&text=Here%20change%20the%20Default%20Action,click%20OK%20then%20again%20OK.
if you cant do that due to access right issue etc. you can try using my snippet, it handles popups using parallel thread
