Hello guys! I have encountered the click generic problem for a few days. I have tried adding delays and timeout but still the problem cannot be solved. Any solutions recommend?
I was trying to make the UiPath click the upload button to upload files to googlesheet.
This is where the error occurs.
lakshman
(Ganta lakshman)
March 16, 2022, 10:37am
#2
@Preeyanan_Sribuddee
Welcome to our UiPath community.
May I know what error are you getting here ? Can you please share screenshot of that error message.
ppr
(Peter)
March 16, 2022, 10:42am
#3
have a check on any indicator reflecting that the upload is doen and try to sync on it e.g. with retry scope activity
Also have a look here:
Here is my screenshot of error.
The error occurred at when to click upload so I cannot even uploaded the file yet. I started to use UiPath months ago so I think it is the latest version now.
Gokul001
(Gokul Balaji)
March 16, 2022, 12:32pm
#6
Hi @Preeyanan_Sribuddee
Have you tried with Click Image activity
Regards
Gokul
Not yet. Could you elaborate more how to use click image? I have searched about it but still not understand.
Gokul001
(Gokul Balaji)
March 17, 2022, 7:11am
#8
HI @Preeyanan_Sribuddee
Use click image activity and indicate on the screen to click the particular field
Regards
Gokul
Hi
Welcome to uipath forum
Just try upgrading the UiPath.UIAutomation package and UiPath.System package in your project and give a try
Go to studio → design tab → Manage Packages → project dependencies → upgrade the above two packages and give a try
Or
If that doesn’t work we have got another workaround where use SEND HOT KEY activity
Use a send hot key activity and indicate that element or button and use key as enter
It’s more like pressing with keyboard instead of mouse
Or
If that doesn’t work try with COMPUTER VISION activities
Or
If that doesn’t work try with CLICK IMAGE activity where select that button as a region of image and then try executing it
Cheers @Preeyanan_Sribuddee
It appears only image click image trigger. How can I find the click image.
My current version is the UiPath Studio 2021.10.5
I am trying to use the click image activities. However, I only see the click image trigger. Is is the same?
Gokul001
(Gokul Balaji)
March 17, 2022, 8:58am
#12
Go to → Manage package → Uipath.UIAutomation.Activities upgrade the package
Regards
Gokul
Gokul001
(Gokul Balaji)
March 17, 2022, 9:00am
#13
And also have a look on the screen shot @Preeyanan_Sribuddee
In the activities panel
Go to → Ui Automation → Image → Mouse (You can find the click image activity)
Regards
Gokul
sb001
March 17, 2022, 9:14am
#14
Can you Pease try once by selecting simulate as input mode property of click image.
Hope this helps.
Saloni
Search completely as click image
It should be there
ushu
(Usha kiranmai)
March 17, 2022, 7:40pm
#16
@Preeyanan_Sribuddee Can you please try with Window Messages as input mode that you can see in the properties
