I need help with clicking on the “Documentation” link using a selector in UiPath. The issue I’m facing is that the selector reads other elements on the screen, as shown in the zoomed-in part of the screenshot (top left). How can I refine my selector to accurately target the link?
Why are you doing UI automation against Windows Explorer? That’s not how you open apps/files. What are you trying to do?
The problem initially appeared with the Gold application (desktop app). The selectors worked perfectly, but strangely today, I wanted to test again and found the issue (in the last photo).
I wanted to eliminate potential causes, so I checked whether this issue was occurring across everything on the VM or just with ERP GOLD. Since I didn’t find other applications on the VM, I tested with Windows Explorer.
Have you tried rebooting?
I believe the screen resolution on your VM may have changed. I would check that
I did check it but it did not change.
I tried rebooting and it worked
It worked thank you
Is there an explanation or it happened with luck?
Sometimes Studio just gets fouled up and you have to reboot.
