Hi everyone,
In a process that opens Edge — where I cannot use “Attach Browser” or “Use Application/Browser” but instead interact with the application via computer vision — how can I check the number of open Edge tabs?
Hi @simone.trenta,
You can try this.
- Click the small tab search/drop-down button near the top-left of Edge’s tab bar or send hotkey “Ctrl + Shift + A”
- The opened panel shows all open tabs.
- Use OCR/CV to count the entries in that list.
If the above one doesn’t work you can also try this:
- Indicate the Edge window - CV Screen Scope activity
- Inside it, add CV Get Text or Get OCR Text activity.
- Configure the OCR region to cover the tab search results list.
Cheers!
Computer Vision identifies and interacts with UI elements visually (e.g., CV Get Text, CV Element Exists, CV Click) Click rather than exposing browser tab metadata.
Happy Automation
on chrome tab if you do shift+esc it gives a view of all tabs as a table..try using cv table extraction to get the table and do a count
cheers
