I have a strange case where i am trying to selecting combination of cells into a string.
For example i have this sheet.
Programid |
Program Brand |
Zip |
Territory Number |
Territory Name |
User Type |
First name |
Lastname |
email |
Phone |
19 |
85 |
45461 |
54864 |
B1 |
TRM |
test |
FRM |
email1 |
19 |
84 |
34561 |
44646 |
B2 |
PPS |
Test |
PSC |
email2 |
19 |
85 |
78957 |
648945 |
B3 |
FCO |
FCM |
Test |
email3 |
19 |
84 |
87654 |
44654 |
B4 |
FCO |
test |
FRM |
email4 |
19 |
85 |
42679 |
548454 |
B5 |
PPS |
Test |
PSC |
email5 |
19 |
84 |
23416 |
5454 |
B6 |
TRM |
FCM |
Test |
email6 |
19 |
85 |
23547 |
54564 |
B7 |
TRM |
Test |
PSC |
email7 |
19 |
84 |
86950 |
564654 |
B8 |
FCO |
FCM |
Test |
email8 |
19 |
85 |
32789 |
654 |
B9 |
FCO |
test |
FRM |
email9 |
19 |
84 |
21345 |
654 |
B10 |
FCO |
test |
FRM |
email10 |
19 |
85 |
32456 |
654 |
B11 |
TRM |
FCM |
Test |
email11 |
I am expecting an Output to be written as below into my variable “Querry2”
‘19’,‘85’,‘email1’,‘19’,‘84’,‘email2’,… and son until row ends
can some once please helpSample.xlsx (9.2 KB)
nbjerke
(Nicholas Bjerke)
2
Hi @syed_Basha
See attached workflow. Hope this helps Get row data.zip (9.1 KB)
sreekanth
(sreekanth)
3
@syed_Basha,AppendRow.xaml (6.9 KB)
Thanks,
Sreekanth.k
Hello Both,
Yes it helps, and also is there any why i can select distinct valuse from each column from the sample excelsheet
Yes it helps, and also is there any why i can select distinct values from each column from the sample excelsheet
Can’t this be written with out code?
Can’s this be done with out code by using activites
sreekanth
(sreekanth)
9
No.There is no activityAppendRow.xaml (10.0 KB)
Refer this file for distinct values @syed_Basha
Thanks,
Sreekanth.k
syed_Basha
(Syed Basha)
10
Hi Sreekatnh,
Thank you very much this works perfectly
I am really sorry to disturb as a final step i have been trying to use join with below command
string.Join(“‘,’”,DT1.AsEnumerable().[Select](Function(row(“Program Brand”))).ToArray())
however seem i can use string from object
shreyaank
(shreyaank)
12
Hi All,
How to convert double to string…im trying subtract two values and getting the below error
“message”: “Assign : cannot subtract a System.Double from a System.String”,
