Why does Building Automation for Mainframe Application Using SBClient give Security Violation 101 Error?
Issue Description:
Using UiPath.Terminal activity and Direct Connection to establish a connection to Mainframe application using SBClient gives "Security Violation 101 Error. You must use a later version of SBClient with this release of SB."
Example Screen Shot below for the connection parameters and the error are as below
Connection Setting
Error
Resolution:
SBClient automation needs to be done with UI activities, as a regular Windows application.
