Build Your First Process With Studio issue post publish it in Orchestrator
Hello,
I have successfully build First process automation in UiPath course, it is giving output result as expected in studio and Orchestrator. If I run the process in studio I can always delete Invoice excel files from Invoices folder in the project directory, but when I run it from Orchestrator it add all new and old Invoice excel files attachments.
Output with studio
Orchestrator Output
Is there anyway I can go and delete old Invoice excel files in Orchestrator so that when I run the process again in Orchestrator it will only display current 4 files and my email will be light also the output will be correct. Thank you.
@sameer.belekar
Add a step in your process initialize state to clear all the files or delete the folder and recreate so that only files are deleted
cheers
Hello Anil_G
Thank you so much providing solution, but I had to do following steps
In initialization added activity Folder Exists
then used If activity
This took care of initialization part
then in processing flow I had to gave full path for few actives like SaveMailAttachment and ExcelApplicationScop
then followed other actives in the automation. It was great relief to get desired output.
Thank you so much UiPath community :slight_smile:
