Hi, I am trying to use for Each Row activity, but body (Do) field is not appearing, kindly help how I can access the do field and why its not appearing.
Hey @Faisal_Muhammad_Shahzad_A !
The “Do” (“Body”) inside the “For Each Row” is nothing more than a “Sequence” activity renamed to “Body” (“Do”)
Then you can drag a “sequence” into the activity and rename it however you like!
Hope it helps!!
