I want to ask one general question here, We have seen 32 bit and 64 bit Operating System.
Is there any other larger size bit Operating System exist? If yes can you please share the link to download it.? I want the best speed operating system.
Hi @bkdroid13
64bit is the best in the machines that we normally use. As far as I know, this is the highest version we have…
Hi @bkdroid13
For any consumer / enterprise use case there are CPU with x86 and amd64 used. There’s no general CPUs at higher technology than 32 or 64 bit.
Every processors with more than this are made for custom use and those have special instructions for given tasks like GPU processors (256 or even 320 bits). Anyway those are not made to perform such things like CPU does.
Answering your question… Even if there would be any OS made for more that 64bits it would not even work on any consumer CPU as translation for example 128bit to 64bit CPU would need more performance than CPU even have
