The trial license for UiPath Studio that I was using for my work has expired, so I was sent a new license key with instructions to install Studio Pro if it had not already been installed.
The only problem is that I am not sure how to check if Studio or Studio Pro is installed.
If Studio Pro is present, then I will just need to activate the new license. However, if Studio is installed then I will need to install Studio Pro. When I open up the program version that I have installed, then it shows the sign in screen, but not which version of the two that is installed.
Thanks for your help.
