Best Practice guide for Solution Architect / Business Analyst
template
#1
What is the use case
It is very difficult to set up a standard procedure for Solution architect and business analyst, most of the projects exceed the deadline due to complex exceptions and there are few exceptions which occur post-deployment, I have seen the Best practice guide for the studio which is outstanding. Can we have similar best practice guide SA and BA?
How do you see a solution for the use case?
There should be a best practice guide for Solution Architect or Business analyst. Which can cover the pointer which leads to project success and project extension or project failure can be avoided.
Scope: ______________
  • Template
  • RPA Documentation
