Automation Suite - How to check Automation suite installed version in kubernetes cluster.
- Login to the Automation Suite server and execute the below commands to see AS version
- export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" && export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" - kubectl get application -A -o wide
- The revision column contains the relevant Product version.
